Wife thinks we're crazy - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4498
    My better half made a rare appearance in the garage this morning as I installed the antenna on the '70.
    "Look, I just installed the antenna! Doesn't it look cool?" I was excited it was on the car again after a drawn out assembly process. (See other post- "How long has your car been apart?")
    "Does it go up and down as you use the radio, or do you need to use a separate switch?" she asks.
    "It's not a power antenna."
    "Can you retract it to prevent vandalism?"
    "No."
    "Well, can you easily replace it if it's damaged?"
    "It's easy to remove and install the mast. But finding an original would be hard."
    "Can't you just put on a new one?"
    "Yes. But the ball size of reproduction masts are a different."
    "Does that mean the radio won't work properly?"
    "No, it means the size of the ball isn't the same. A Corvette guy would notice." I felt a bit lame saying this out loud.
    "You guys are crazy." She said as she turns around and goes into the house.
    Maybe so, I thought. But I think it's cool the antenna is the same age as the car.
    Even though this hobby sometimes drives me crazy, it's helped me remain curious and sane while living life. And since you're reading this, I suspect you too have an outlet to remain curious and sane.
    Cheers to caring about the ball size of our antenna.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Loren L.
    • April 30, 1976
    • 4104
    Re: Wife thinks we're crazy
    Mark, I think you have to work on your presentation..........
    • Philip A.
      • February 26, 2008
      • 329
      You just need to explain it in terms she understands. NOS = GIA certified diamond, Repop = cubic zirconia
      • Greg G.
        • March 10, 2016
        • 10
        Hahaha that was good. She will understand that for sure!
        • Richard G.
          • July 31, 1984
          • 1715
          Nailed it.
          My wife knows what this stuff costs.
          Top Fiight = a certain amount carats.
          • Terry D.
            • May 31, 1987
            • 2690
            Mark
            I have a similar story, upon finally getting my 62 on the road, late fall, I realized heater motor did not run. Took it apart cleaned and sanded and replaced brushes, a few days later I put it back together hooked to a battery and it ran right away. I'm delighted and take it into the house and tell my wife " it works" to which she replies " isn't it suppose to?"
            • Tom D.
              • September 30, 1981
              • 2126
              This discussion system makes suggestions at the bottom - Automatically searches for things that might be related...
              Here's one that was suggested when I looked at this
              https://www.forums.ncrs.org/showthre...is-away-part-2
              Remember it?
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Steve B.
                • March 1, 2002
                • 1190
                Mark, I look at it this way, real parts on real cars matters
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Wives' main job is to keep your ego deflated....
                  I painted my 63s red headliner with dye on the top of the shrubbery in front of the house and turned them a bit reddish; the wife got upset. So I went back and painted the affected areas green - she got more upset...
                  I don't understand women...
                  • Mark E.
                    • April 1, 1993
                    • 4498
                    Remember it?
                    Hadn't seen this before. Too funny.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Mark E.
                      • April 1, 1993
                      • 4498
                      Thanks Loren. But I've heard that before.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Michael J.
                        • January 27, 2009
                        • 7073
                        My wife got interested in judging things after I failed PV for the second time. That was an interesting conversation to explain it all to her........
                        • Richard F.
                          • 498
                          So one day my daughter says to me "Dad what is it with guys and cars", I say you know it's like women and shopping, "O.K. I get it now"
                          My wife why torture her?
                          Rich
                          • Gene M.
                            • April 1, 1985
                            • 4232
                            Mark your wife is right this is a sickness and no real cure.
