63 chrome interior moldings - NCRS Discussion Boards
  • Andy S.
    • March 12, 2014
    • 13
    My 63 SWC has chrome interior windshield, headliner, and rear window moldings. Looks great but was this ever correct?
  • Russ S.
    • April 30, 1982
    • 2161
    Re: 63 chrome interior moldings
    I am not a 63 person but I believe that is correct for 63.
    • Peter H.
      • April 1, 1980
      • 223
      To the best of my limited knowledge i recolect they were painted interior colour...peter...coupes that is....
      • Loren L.
        • April 30, 1976
        • 4104
        My coupe is chromed and they look good BUT that was the result of its short show-car career 1968-72(?) as a CANDY-APPLE RED (inside & out) show car. The gouges in all of the interior mouldings must have been made by 36 grit - "Just keep painting until the holes fill". In 1972 some of those pieces were ALREADY "unobtainium" - asked a plater if he would do all the interior mouldings in chrome for $100 - SOLD!
        • Frank D.
          • December 27, 2007
          • 2703
          I have to believe chrome windshield interior pieces would be darned hard on the eyes in the sunlight.....worse than the "alleged" lack of rear window visibility due to the split for my money...
            • 15610
            All interior garnish moldings were painted to match the interior color. For Riverside Red there are three paint codes, and I believe the only difference is gloss. For example the lower windshield garnish molding is flat, and I expect the other interior colors followed the same pattern.
            • Joe R.
              • July 31, 1976
              • 4547
              Not all interior garnish moldings were painted (example: interior vertical windshield holdings were stainless right and left) . Would recommend you find a 63 that is known to be original in your interior color. Saddle Tan would be the most complicated as it used two different paints and finishes.
              JR
              • Harry S.
                • July 31, 2002
                • 5258
                From a July 19th 63 coupe, silverblue/black. All moldings around the front and rear windows are painted black. From an April 19th 63 Conv, Black/Saddle. Windshield, top and side molding stainless, probably flash chromed originally. Bottom trim at dash is painted interior color.
                • Perry M.
                  • January 1, 1977
                  • 325
                  All the garnish moldings on my June 63 saddle tan coupe interior are painted. No stainless or chrome.
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    JR, I think Duke is talking coupe.
                    • Andy S.
                      • March 12, 2014
                      • 13
                      The car i have is a red/red L76 SWC built July 9 and all moldings are chrome all around. The car is mostly original and therefore i do not want to paint moldings just in case they were factory chromed. How many points might this cost me at regional if, in fact, this chrome is not original?
                        • 6940
                        Andy, 63 Coupes interior moldings were all painted gloss except lower is low gloss, convertibles windshield sides and upper where flash chrome, the lowers were low gloss. convert. with hard-tops had all rear window and side piller moldings painted gloss.
                          • 6940
                          Andy, you'll need to find the point values on interior trim and then deduct 20 percent on the finish. so I found a interior judging sheet all the moldings are worth 15 points. so looks like 3 points
                          • Donald L.
                            • November 1, 1981
                            • 140
                            63 all interior trim pieces were painted interior color. From the factory some of the pieces were chrome or stainless steel under the paint. The paint did not adhere very well to it and would chip off, apparently they had intentions of putting all stainless steel inside the car and realized the reflection would not be good.
                            • Joe R.
                              • July 31, 1976
                              • 4547
                              Sorry, as I was referring to a Convertible. My bad!
                              JR
