Fuelie Startup - NCRS Discussion Boards
Fuelie Startup
  • David C.
    • June 30, 2006
    • 126
    Fuelie Startup
  • Dan H.
    • July 31, 1977
    • 1365
    Re: Fuelie Startup
    Not as designed, when starting 380 unit on 64/65 the bypass solenoid opens allowing raw gas from the engine fuel pump to flow directly into the injector fuel spider and into the engine. IT will flood if warm, owners manual even states to depress gas pedal to over ride the bypass solenoid and prevent hot car flooding. Not normal.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • John S.
      • May 4, 2008
      • 424
      Re: Fuelie Startup
      Agree with Dan 100%.
      John Seeley
      67 Black/Teal
      300 hp 3 speed coupe
      65 Maroon/Black
      35k mile Fuelie coupe
      • Jim L.
        • September 30, 1979
        • 1805
        Re: Fuelie Startup
        Originally posted by David Ciaramello (45974)
        .... without touching either the gas pedal or the throttle
        Huh?
        What about the foot feed? Did he cheat and depress it?
        • Michael J.
          • January 27, 2009
          • 7073
          Re: Fuelie Startup
          Me too, hot fuelie needs pedal to the metal to start.
          • Steve B.
            • March 1, 2002
            • 1190
            Re: Fuelie Startup
            I never knew that about fuelies. What is the correct cold start procedure?
            • Don H.
              Moderator
              • June 16, 2009
              • 2236
              Re: Fuelie Startup
              This ---- >
              • Michael J.
                • January 27, 2009
                • 7073
                Re: Fuelie Startup
                I think many people do not know that fuelies have a high pressure fuel pump (downstream of the low pressure one on the block) that is driven from the tachometer by a cable like a speedometer cable. When cold, with the choke set, cranking it supplies high pressure fuel to the injectors. So no need to hold the throttle down to start it.
