Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
67 BATTERY gauge -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I,am trying to understand my Battery gauge, at idle 850 rpm it reads a little pass zero as i increase rpm it goes toward +40 then back to zero when idling, charge system reads at battery 13.5 at idle when increase in rpm it goes 13.9 to 14.1 with no headlights on, my question is this normal operated for the Battery gauge needle to swing from zero to +40 , Danny
If car has been off for 24hrs or more, the Ammeter (battery) needle will jump to around +40 when it first starts, but then immediately starts dropping back towards 0. As long as engine is running, gauge reads slightly positive. Turn engine off, and needle will point straight up, aligned with the 0 line. Open a door, turn ignition to "on", or turn on lights, needle will move left (negative) of center. Start engine, needle always shows a positive charge. Yours seems to be reading properly. This assumes your battery is in good condition.
