C1 gas tank fit - AGAIN - NCRS Discussion Boards
  • Terry K.
    • July 31, 1975
    • 82
  • Darryl D.
    • February 7, 2017
    • 386
    Re: C1 gas tank fit - AGAIN
    I don't know about the fit but my 57 has a replacement tank that I have never been able to get more than 14 gallons in it when it is out of gas.
    • Donald H.
      • November 2, 2009
      • 2580
      I restored a 60 with a new tank in 2011 and it did not fit. I messed with it off and on for two weeks. Tried bending the pinch welds and everything. The reproduction simply did not fit. This was the Quanta tank that is supposed to be correct. Finally gave up and used a BFH.
      Maybe in the last seven years, the design has been corrected!!
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Keith R.
        • August 31, 2001
        • 660
        I had a devil of a time getting my Quanta tank in as well vs. the original which went right in. After bending the corners down and struggling with it for a while it went in okay. By the way, if you have a choice, get a '61 or '62 tank which has the baffles in it which might help with the design flaw of gas coming out the fill tube in a right hand turn.
        Keith MacRae
        NCRS #36692
        New Mexico Chapter
        1960 290HP FI
        2013 427 Convertible
        Shade tree mechanic and
        B-52 pilot extraordinaire
        • Robert I.
          • July 31, 2004
          • 164
          I'm trying to fit a new Quanta tank into my 62. When I pulled off the tank access cover, I expected to see a build sheet on top of the old tank, but there was none. Therefore, I suspect the old tank was actually the 2nd tank. Anyway I can't get it to fit into the space. I wonder if I trimmed off the folded down metal, if it would then slide in? Has anybody tried that?
          I sure don't want to ruin the tank.
          ____________________
          Bob Immler
          • Mark S.
            • July 31, 1983
            • 655
            The metal edges need to be bent to fit in a 56/57 for the Quanta tank.
            • Don H.
              • December 1, 1981
              • 1482
              There was not a build sheet on solid axles, I think it started in 1967.
              • Robert I.
                • July 31, 2004
                • 164
                "There was not a build sheet on solid axles, I think it started in 1967."
                Thanks, I never knew that!
                Bob Immler
                • Mark S.
                  • July 31, 1983
                  • 655
                  The AIMs started in 1957. That isn't to say there was an informal one before that. I have an original 57 print from GM.
                  • Mark S.
                    • July 31, 1983
                    • 655
                    This is another piece of information from the build sheets.
                    • Thomas H.
                      • August 31, 2005
                      • 1053
                      When I replaced the tank on my 60, I used the "correct" Quanta tank - didn't fit. I had to fine tune the flanges a bit with a hammer. It then dropped in without issue.
                      When I did the 58, I bought another quanta tank and expected to need to "tweek" the flanges like I did with the 60. Well after beating and banging on the flanges with a rubber mallet I ended up breaking out the BFH and a 2x4. it STILL would not fit. I ended up reparing and cleaning the original tank which fit like a glove.
                      I took some measurements between the two tanks and if I remember correctly the Quanta tank was about 1/4 to 3/8" larger in circumference then the original. Given the tight fit of a tank made to the correct size, no wonder it wouldn't go in.
                      Tom
                      2007 Z06, Lemans Blue
                      • Robert I.
                        • July 31, 2004
                        • 164
                        Yesterday I stopped at a small market to get a snack after a bike ride. I saw a nice Hudson Hornet outside. As I was taking a photo, the owner came out. He was wearing a Corvette hat. Turns out he has a 56. Asked him if he'd ever replaced the tank? Yes. He claims the tanks are different. I think the only difference is whether or not they have a vent tube and/or baffles. Called Quanta this morning. The person that answered is just looking it up, has never replaced a tank themselves.
                        Bob Immler
