C2 Glove Box Door Face Plate Supplier
Tags: None
Re: C2 Glove Box Door Face Plate Supplier
The brush finished aluminum that was offered was incorrect. The brush finish is not like originals, better to source a piece of aluminum from metal suppliers and brush finish it yourself so it looks correct. You will need to size it to suit the application and drill holes. I’ve had offerings of restored doors in the NCRS want ads with no takers.- Top
Mike,
Give Eckler's a call...they still show in their online catalogue...minimum supply.
Leif
Top Flight 2017 Lone Star Regional- Top
You have the article from years ago on how to "replace" it while leaving the rivets intact?Attached FilesVice-Chairman (West), Michigan Chapter NCRS
Mike,
Here's Bob Young's method with pictures as published in the RestorerAttached FilesJerry Fuccillo
1967 327/300 Convertible since 1968- Top
Thanks Jerry and Patrick for posting the procedure. That is the process I plan to use. Wish me luck!
cheers,Mike Andresen
Bloomington, IL- Top
