What happened to Quanta??? - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1715
    Re: What happened to Quanta???
    I used the original straps and had zero issues with the replacement gas tank installed in my 63.
    I may add is was one of the few items, that was aftermarket, that went in and worked as designed.
    Only issue I had was with the imported fuel gauge sensor not holding the sensor tight.
    When I changed out the import locking ring for the one that came with the tank it worked perfectly.
    And when I went back and changed out the gauge sensor for a OEM one it worked perfectly also.
    Rick
    • Richard R.
      • January 5, 2010
      • 267
      my 69 L46 gas tank from quanta fit perfectly as well. No issues. Used the original straps. body is on and finishing up the resto now. Just beware of the alternator belt for a 69 L46. Their stock belt is too long. see my response to an old post today.
      Rich
      • Ken A.
        • July 31, 1986
        • 929
        #18
        FWIW, Quanta does not make gas tanks, they are sourced in Canada.
        • Justin S.
          • July 3, 2013
          • 289
          #19
          https://www.forums.ncrs.org/showthre...tank-centering
