Taps - name and source - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    I've seen - but do not have - a tap "sleeve" that opens in the middle and can be installed on good threads.....located ABOVE those threads where Bubba attempted to use the bolt as a punch to remove a 50 lb plug in a sewer main......or even something smaller. Need a proper name for such tool where a seller will know what I'm talking about and give me one for my birthday.....HELP!
  • Richard G.
    • July 31, 1984
    • 1715
    Re: Taps - name and source
    I believe this is what you might be looking for;
    Made in metric and SAE.
    • Edward B.
      • January 1, 1988
      • 537
      • Loren L.
        • April 30, 1976
        • 4104
        Problem solved. Thanks to all.
        • Gary R.
          • April 1, 1989
          • 1796
          Those are pretty slick. I might invest in a set.
          • Richard G.
            • July 31, 1984
            • 1715
            The only thing holding the two haves together is the socket as there is no special tool to retain them.
            Better than nothing? Yes.
            Especially if used with a factory recommended 6-point socket.
            Cure all, not quite.
            I did manage to save a couple bumper bolts using this system.
            However, they still started funny and I had to be careful not to start the bolt with force and confirm it picked up the correct lead.
            If the bold can be removed and the dies held in a vise and the screw backed through the tap one can expect better results.
            If I can get the screw or stud off and into my lathe I can chase the threads with better results. But this method is time consuming.
            Don't forget the application of cutting oil for best results.
            Rick
            • Edward B.
              • January 1, 1988
              • 537
              If the bolt can be removed, what's the need for the split die?
              • Richard G.
                • July 31, 1984
                • 1715
                To save our specialized unobtainium NOS bolt!
                • Bill M.
                  • 1317
                  If bolt can be removed but starting threads are damaged you mount the die on the good threads and back it off. Hoping to rethread the damaged threads
