427 Block - NCRS Discussion Boards
427 Block
  • Walter R.
    • January 6, 2009
    • 269
    427 Block
    Is there any difference in a 427 block with 425 HP and block with 390 HP?
  • Roy S.
    Past National Judging Chairman & Concours Team ******
    • July 31, 1979
    • 1022
    Re: 427 Block
    Short answer Yes. I will leave it to the experts to explain.
      Re: 427 Block
      Walter------
      The block CASTINGS are the same. The difference is in the machining of the blocks. The L-36 block is machined for 2 bolt main bearing caps; the L-72 is machined for 4 bolt main bearing caps. In addition, for the L-72 there is machining in the area above the oil filter for oil cooler plumbing. For the L-36 there generally is not such machining. I've heard of some L-36 blocks being found with it, though.
      An interesting side note: the bearing caps on 4 bolt main engines were not made of the same material as the block. The block was made of gray cast iron; the main caps were made of ductile/malleable iron, a much stronger material. For the 2 bolt caps, I'm not sure. I don't know if they were gray iron, nodular iron, or ductile/malleable iron.
      • Walter R.
        • January 6, 2009
        • 269
        Re: 427 Block
        Thanks Joe and Roy,
        I should have mentioned that mine has 4 bolt main and I knew that differentiated the 390 from the 425. Bought block about 5 years ago and when I purchased I knew the 4 bolt differentiated the two engines but I had forgot. One other thing is the block I have is standard bore and no markings on the engine pad. I know that could mean the engine was decked or the stamping was sanded off but I don't think so as pad looks extremely consistent. I was told this is probably a service block as they came with no stamping on the pad. Your comment would be appreciated.
        • Roy S.
          • July 31, 1979
          • 1022
          Re: 427 Block
          Post a picture of the engine pad deck surface! Or send it to me as a private message if you do not know how to post or do not want to post a picture.
            Re: 427 Block
            Thanks Joe and Roy,
            Walter------
            Yes, SERVICE bare or fitted blocks usually had no numbers stamped on the engine pad.
            I have heard of other cases, though, in which 1966 L-36 originally had 4 bolt mains. 1966 Chevelles with L-34 (360 HP) usually had 4 bolt mains. The L-34 is the 396 cid equivalent of the L-36.
            • Michael J.
              • January 27, 2009
              • 7073
              Re: 427 Block
              I have heard of replacement long block assemblies with the plant, assembly date and suffix on the pad.
              • Walter R.
                • January 6, 2009
                • 269
                Re: 427 Block
                Engine in machine shop. Will post when available. Thanks.
                • Justin S.
                  • July 3, 2013
                  • 289
                  Re: 427 Block
                  Joe,
                  Wouldn't the valve reliefs be cut on a 425 hp block as well?
                    Re: 427 Block
                    Originally posted by Justin Sibbring (58615)
                    Joe,
                    Justin------
                    Yes.
