Relocating Harrison Evaporator Sticker - NCRS Discussion Boards
  • Jeff W.
    • December 20, 2015
    • 101
    My Harrison sticker on my evaporator INSIDE the case is perfect. Any suggestions on how to remove it to relocate it to the exterior of the case?
    Best regards,
    Jeff
  • Richard F.
    • September 30, 1981
    • 498
    Re: Relocating Harrison Evaporator Sticker
    Jeff
    In the Art World there is a product named Bestine, this is a non aggressive solvent that will release the contact cement without damage to the original piece. Applied with an eye dropper next to and around the label, let it "crawl" under the label and carefully remove when the label is still wet and let dry.
    Rich F.
    • Jeff W.
      • December 20, 2015
      • 101
      Interesting. Thanks! I will give that a shot.
      Jeff
      • Jeff W.
        • December 20, 2015
        • 101
        I went to apply the Bestine and found the label disappeared when I had the evaporator cleaned. Bummer! It was perfect.
        • Brad Hillhouse (37766)
          Jeff - my 5000 car had the Harrison decal on both the evaporator core and the evaporator case.
          Brad Hillhouse
          37766
          • Jeff W.
            • December 20, 2015
            • 101
            Hey, why don't you send me that one from the inside?
              Jeff
              you can have it, just have to go in and get it!
              Is your evaporator dated on the other side?
              Brad
              • Jeff W.
                • December 20, 2015
                • 101
                Good question? What are all these marks?
