Just finished rewiring my 66 Coupe with new front and under dash harnesses. I gotta say right here that I'm pretty darn proud of myself, because I've never done a project on a car quite this involved. it looks real pretty and I don't have any short circuits, and everything works with one exception, turn signals. I'll start with what IS working in the turn signal system.
1. I have a rt turn signal indication on the cluster and a rt turn signal on the rt tail light and rt parking light.
2. I have headlights and tail lights all around, the only exception being no high beam headlight on the left front. (probably the lamp).
3. I have both brake lights and a rt turn signal with the brakes on (rt turn selected)
WHAT I DO NOT HAVE:
1. No left turn signal on the cluster but the left turn signal works on the left tail light
2. No left turn signal on the left front parking light, whether the parking light is on or off.
Questions: where should I start troubleshooting first? Is it possible that this is a turn signal switch problem? Flasher problem? And another unrelated question. My parking lights are on in the parking light position on the light switch, but when I switch on the headlights, the parking lights extinguish. Is this normal?
I should add that the wiring harness on the steering column is original, but the under dash (dual plug) connection is of course new.
Thanks in Advance for any troubleshooting suggestions you all may have, hopefully starting with the easiest first.
WHAT I DO NOT HAVE:
