I was hoping to get some pointers as I try to get my 72 A/C to work properly. Here is the current status:
My system was working fine with a previous retrofit to R-134a.
The A/C stopped blowing cold.
My POA valve was apparently stuck as I was getting the same psi readings on both the hi and the lo side, so I replaced it with a "restored" original POA valve which I tested before installing with compressed air (I assume is it set up for R-12). I input 75 psi and the output was 28 psi. I installed that valve, evacuated and charged the system.
Performance test results:
No Cooling in interior.
Running R-134a -- I put in 2.6 lbs. per specs.
Ambient Air Temp= 80 deg. F.
Engine RPM= 2,000
Inside temp at vent= 80 deg. F.
Pressure Readings= Lo = 30 psi Hi = 144 psi
POA valve is icing up at outlet end. Compressor hose -- Lo fitting is cold and icing at the compressor fitting.
When running, the Sight glass shows bubbles. When the engine is shut off, sight glass foams then clears within 30 sec.
My thoughts are that my compressor may be worn out, but I am hoping it's not something so drastic.
Any ideas would be appreciated.
Mike
Engine RPM= 2,000
Mike
