65 Telescopic column - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    I need to obtain about one more inch of length between the steering wheel and my stomach. I now have a standard column in my coupe and am considering changing to a telescopic column. Does the tele column push further in toward the cluster then the standard column?
    Dave K.
  • Bill M.
    • 1317
    Re: 65 Telescopic column
    that's a good question. I have both so I will check when I get home. I to have problems with my standard column getting longer over the years.
    • Tom D.
      • September 30, 1981
      • 2126
      I cannot measure until Monday - My GUESS is that the tele column will allow a little more room.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Dave K.
        • November 1, 1999
        • 951
        Thanks Tom.
        Dave
        • Tom D.
          • 2126
          Werner Meier of Masterworks in MI: No gain from a tele. You CAN adjust a standard column so there is more of it in the rag joint.
          Option 2. Use a flatter smaller steering wheel such as from a 1969 Corvette. (You will have to bend the turn signal lever.)
          Option 3. You know that one.
          Michigan Chapter
          Tom Dingman
          • Bill M.
            • 1317
            I measured both columns.
            My 65 tele fully retracted had 7 5/8" to the base of the dashboard
            My 67 standard column had 8 1/2" to the base of the dashboard.
            So actual measurements show 7/8 " difference.
            The tele fully retracted is closer to your lap so you may have to extend when leaving seat
            • Dave K.
              • November 1, 1999
              • 951
              Bill,
              Does your 65 tele column have the correct tele rag joint or are you using a non tele rag joint?
              Dave K.
              • Bill M.
                • 1317
                It is a restored car but I would have to double check that to be sure.
                • Dave K.
                  • November 1, 1999
                  • 951
                  The correct rag joint gives the Tele column more compression length.
                  Dave
                  • Bill M.
                    • 1317
                    I will check and see. I never had a reason to find out there was a difference. Is there anyone in your area of Pa who has a car with that option so you could try it out?
                    • Bill M.
                      • 1317
                      yes it is a telescopic joint flat coupling on the box and bolted to the column half. I wish I could post picture but never have any luck
