Ever since I have my ‘65 Corvette - now 12 years - I have been experiencing low temperature reading (as low as 150) when cruising steadily - otherwise it is between 180 and even above 200 when driving behind a very slow tractor up a hill. I checked the thermostat housing area with an IR gun to verify the accuracy of the gauge, which is ok. I replaced the thermostat - (180 degree Mr Gasket). The aftermarket fan clutch has more resistance when engine is hot - apparently ok. So I gave up ...
Today I decided to order a replacement fan clutch only to discover that the currently installed one is most probably a Four Seasons 36954 (I have the respective box with the part number on it from when I bought the car). Could a wrong fan clutch cause lower temperatures when cruising?
Oliver
Oliver
