I wonder if anyone can give me some advice or insight as to why my radiator shroud is not clearing the fan. I have just completed installing a new radiator support from coffman. The fan was hitting the shroud already unless I pushed it up on top of the screws in the bottom of the support. I assumed my problem was from the badly deteriorated original support that I replaced. as can be seen in the photos it still hits the shroud
.. I know I need to shim the bottom of the support but it is already about 1/2 in off the lower frame member. I'm wondering if maybe I have the wrong engine mounts. I tried to get some pics of these. Also I know I have the wrong water pump maybe this one has the spindle too high some how
. The fan is 17 1/2 inches pretty sure that the right one.
