Fuel Pump Restoration
Re: Fuel Pump Restoration
Some more info on the topic...its for a 61 but the pumps with the screws are basically all the same...Attached Files- Top
The fuel pump diaphragm spring sets the fuel pressure.
There have been reports of replacement having incorrect spring compression strength resulting in high fuel pressures at the carburetor.
I would confirm the spring in the rebuild kit is close to the same length and wire size as the original.
If your old one looks good I would consider re-using it and installing the rubber parts from the kit just to be sure.
If you really want to confirm the pressure correct hook up a gauge at the output and stroke the pump by hand. This can be done with the pump held in a vise while stroking the lever with a hammer handle. The pump can be dead-headed it will not hurt anything. A fuel pressure gauge with the extra port to dump the fuel pressure after testing works great.
Because there is no good way to connect the gauge testing the fuel pressure with the car running is a pain.
Here is how I do it:
1) Start the car and warm it up for a minute or so.
2) Disconnect the line to the carburetor and adapt it to the gauge.
3) Start the car, it will run for a short time on the fuel in the carburetor.
4) Pressure can be read even if the car will not start just by turning the motor over on the starter.
I have little confidence in the current aftermarket parts. Too many of them are made overseas with no quality control.
I test everything I can to eliminate the variables.
What year Corvette you are working on? I am assuming pre-electronic fuel injection and it is early enough to have the pump that is not crimped together.
Rick- Top
Brian, if you are referring to the July- August 2018 issue of the Redline Times it is not yet posted to the chapter website. Latest version posted is January 2018. If possible, can you attach a PDF of the issue or just the fuel pump article?Ed- Top
