63 hubcap set - NCRS Discussion Boards
63 hubcap set
  • Wally A.
    • May 31, 1979
    • 170
    63 hubcap set
    heading for Carlisle next week. What should i pay for a nice frosted set of 63 hubcaps?
    or by chance if you know someone willing to sell, above driver quality.... thanks for your time
    had my fill of Ebay
  • Tom D.
    • September 30, 1981
    • 2126
    Re: 63 hubcap set
    Wally: You should see several there. Look around before you buy, and stop by to see the gang from Waterford at G1-G3.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Harry S.
      • July 31, 2002
      • 5258
      Re: 63 hubcap set
      Wally, since you said NICE and above driver quality, I woud think an unrestored frosted set without dings is somewhere between $500 and $750. Just as a reminder a reproduction set of bars and spinners is about $800. Even if you restored a set yourself your starting cost is the stainless and the labor to remove the dings and scratches and to polish. A restored set of frosted must be in the area of $1300.
      • Wally A.
        • May 31, 1979
        • 170
        Re: 63 hubcap set
        makes good sense, wish me luck
        • Frank D.
          • December 27, 2007
          • 2703
          Re: 63 hubcap set
          Harry has it right Wally....
          The problem is nobody wants to hardly restore these hubcaps -- last price I got was $300 per cap...
          Its hard as the dickens to get the dings out of the curved circumference so yeah, not cheap....
          I have a set of frosted platters on the shelf if nothing else - if you could find somebody to restore them...
          • Joe R.
            • July 31, 1976
            • 4547
            Re: 63 hubcap set
            Wally,
            There are four different designs of 63 Hubcaps. Which one corresponds to your 63? I have approximately 20 63 hubcaps and probably not a good one in the bunch. All need the bumps and bruises fixed. Don't know anyone that's an expert on removing those bumps from the rims of a 63 hubcap. Good luck at Carlisle.
            JR
            • John D.
              • December 1, 1979
              • 5507
              Re: 63 hubcap set
              I have seen Andy Cannizzo's restored '63 "wheel covers" and they are perfect. He's able to remove all the dings. John
              • Frank D.
                • December 27, 2007
                • 2703
                Re: 63 hubcap set
                I haven't seen anything Andy does that isn't perfect....
                He restored three 63 shifter consoles for me and sold me a set of date-coded, correct 63 horns...
                I did not know he did the hubcaps....I think he also does rocker covers though - the right way too...
                • Chester C.
                  • May 29, 2013
                  • 154
                  Re: 63 hubcap set
                  I would like to know his process of removing dents that on the outside of cap. As we all know the edge of the cap is metal on top of metal. Only way to remove dent that I know of is cut inside metal off where the dent so you can hammer the dent out or beat the inside metal until it hits the outside dented metal to remove. Either way sounds scary.
                  • Thomas S.
                    • February 7, 2016
                    • 603
                    Re: 63 hubcap set
                    Wally,
                    I have a set of frosted caps that were not correct for my late 63. I ended up getting restored inner caps and swapping the fins and spinners. If you are local to northern NJ you are welcome to stop by and take a look. They are in very good shape and probably don't need any work whatsoever (in my opinion). You would need new spinners and fins of course but those items are hard to restore anyway. Sent you a PM.
                    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
                    • Douglas C.
                      • September 30, 1988
                      • 221
                      Re: 63 hubcap set
                      I remember being at Bloomington Gold in 1990 and a vendor had about 10 20-Gallon trash cans. Each can held nothing but '63 Hubcaps, stacked to the top. Probably around a 15 or so hubcaps to a stack.
                      I went through every can and every cap and couldn't find a single '63 cap that hadn't been dinged hard on the edge.
                      Made a big impression on me to think how many cars had been parted out or wheels changed out to produce that much surplus.
                      I have a set of 4 currently hanging in my garage just for wall art - all with dings.
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        Re: 63 hubcap set
                        Andy isn't really "free" with his process information - sorta proprietary I think.....I've asked about his process to produce 63 date coded horns and he deferred.... There is a reason the restoration costs are so high.... I haven't studied the back of my restored set of wheel covers to try to determine the technique but I prob could...
                        I know the restored covers go on my Corvette Specialties reproduction 63 wheels like a dream....all the drama, bruised palms, dings and nerve-wracking pounding with a mallet are no more.....just a few sharp raps with a fist in a workout padded glove and its done..
                        • Wally A.
                          • May 31, 1979
                          • 170
                          Re: 63 hubcap set
                          thanks for all of your input. from what i can tell, 63 caps are not dime a dozen. leaving for Carlisle next week in the hunt for a set of caps.
                          sure they wont be cheap, but won't be first time biting a bullet. will report after Carlisle what the real story is finding a set of caps and
                          the going prices. should be interesting. stay tuned. again thanks for all your input and advice...hope next time the 63 is out will be
                          without its knockoffs....funny thing, when these cars were delivered to the dealers, they were all hubcap cars... today as you all know
                          knockoffs seem to be the norm...on most of them.. stay tuned Wally
                          • Kenneth F.
                            • 282
                            Re: 63 hubcap set
                            Hi Wally, https://losangeles.craigslist.org/sg...672247385.html
                            Ken
