Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 L71 Holley plating issue - NCRS Discussion Boards
  • Daniel S.
    • February 1, 2000
    • 164
    Had an issue last week when starting my 68 L71 where fuel was shooting out of the top vent of the front carb. Removed the needle and seat hoping to find debris but none found.
    Pulled the carb and removed float bowl. Found that the plating has hanging off of the metering plate and began to crumble off as soon as I touched it. I believe the float was hanging up on the plating which caused the issue.
    Decided to investigate further by removing the metering plate and gaskets. Found the same thing was happening on the main body of the carburetor where the plate attaches.
    I did not take a picture of the main carb body as I found it. That attached pic is after I cleaned the carburetor body.
    I could just purchase a new metering plate but my question is what to do about the missing plating on the main carb body.
    Pretty confident that it would be a mistake to reassemble with new gaskets without addressing the issue as I'm sure the metal needs to be protected.
    Is having the carburetor re plated my only option?
  • Danny P.
    • Today
    Re: L71 Holley plating issue
    i would first try if it would works by getting a aluminum file and file down the main body so it not warp and check for cracks and passages block then get the main body re plated and clean and then install a new or a good used metering jet and plate with new gaskets and set up your floats and see what happens, very simple setup 2300 Holley, some one went crazy and seem to over tighten this meter plate screw ???
    • Gene M.
      • April 1, 1985
      • 4232
      What are you using for fuel?
      • Daniel S.
        • February 1, 2000
        • 164
        Actually those metering plate screws were not tight. The plating lifting off in the picture gives the appearance that the screws are too tight.
        Dan
        • Daniel S.
          • February 1, 2000
          • 164
          Non ethanol with a splash of AV100 low lead to bump up octane a bit. The inside of the fuel bowl looks good. No loss of plating. Just the metering plate and the main body of the carb where the metering plate bolt up has plating loss
          • Chris H.
            • April 1, 2000
            • 837
            Daniel, a related thread.
            https://www.forums.ncrs.org/showthre...highlight=bomb
            • Daniel S.
              • February 1, 2000
              • 164
              Chris--
              Great read, thanks. I see you experienced this as well. Did you have your Holley 2300 re plated? If so, has the re plate held up well?
              • Chris H.
                • April 1, 2000
                • 837
                Daniel, I just cleaned / dremmel wire-wheeled all the loose stuff as best I could, then sprayed everything with carb cleaner and blew everything out with compressed air. Knock on wood, it's been 2 years now and the car is running great.
                • Daniel S.
                  • February 1, 2000
                  • 164
                  So you left the bare metal exposed after cleaning it up without a re plate?
                  I would like to do that as well but came to the conclusion that the plating was there more for the pot metal protection then for looks
                  • Chris H.
                    • April 1, 2000
                    • 837
                    Daniel, yes just bare metal. Would be interested in re-plating if such a service exists.
                    • John M.
                      • January 1, 1998
                      • 813
