How do you tell the difference between the one for a small block versus the big block one? Thanks
1973 air cleaner to hood adapter ring
Re: 1973 air cleaner to hood adapter ring
Mike,
The BB flange offset is elliptical in shape, while the SB ring flange offset is concentric. The arrows in the first photo below highlight the narrow offset on one end. The center is an original 73-74 454 ring. The last photo is an original L48/L82 ring to show the difference.
Hope this helps!Jimmy
1973 Convertible
L48,M20,N40
Mille Miglia Red/Oxblood
- Top
Great info Sal! I have had a collection of 6-8 of these A/C for years and hadn't heard of the height difference before so I checked them and you are correct. The over-all height is about a 1/4 inch less on the BB and the effective height (from top of the air cleaner to the top of the ring) is about a half inch shorter on the BB.- Top
Russ,Great info Sal! I have had a collection of 6-8 of these A/C for years and hadn't heard of the height difference before so I checked them and you are correct. The over-all height is about a 1/4 inch less on the BB and the effective height (from top of the air cleaner to the top of the ring) is about a half inch shorter on the BB.
You saved me an email! I was just about to ask you to measure yours. This info will be great to point out in the revision. BTW, the first two photos in my thread above are from Russ....
Sal,
While we're on this sudject, why the elliptical shape on the 454 rings? Is the distributor mounted up closer to the carb, or is the BB mounted back a little further?
Thanks!Jimmy
1973 Convertible
L48,M20,N40
- Top
Overall height of the LS4 ring is 1.350 The OAH of the SB ring is 1.725 Going price approx. $250-300. unless you get lucky.- Top
Tom Russo
78 SA NCRS 5 Star Bowtie78 Pace Car L82 M2100 MY/TR/Conv- Top
Reviving on old post here but Terry in Perth is doing an NCRS resto on his 73 LS4 and cannot find a LS4 air cleaner flange for love nor money!
It is the one Jimmy describes in Post #2.
Any clues where he can obtain one?
Gary
Perth, West Australia- Top
Hi Gary,
Might want to check with Russ who posted above to see if still has any that he might part with. I'm sure he'll see this post. Every now and then one would show up on eBay but I haven't seen any for quite awhile. Just checked and there's someone selling the 454 seal and ring on there now for a lot of $$$$$. You could also check with David Sokolowski who advertises many parts for sale in the Driveline. Be specific with your request, not too many folks know about the differences.
Good luck
Jimmy
1973 Convertible
L48,M20,N40
- Top
- Top
