1964 Brake/clutch pedal assembly questions - NCRS Discussion Boards
  • David R.
    • February 1, 1990
    • 71
    I am working on the brake pedal assembly for my 64. I am hoping someone here can help me with the finish on a few small parts. What finish is correct for these parts?
    Non-power brake pushrod
    Pushrod jam nut
    Clevis
    Clevis pin and retaining clip
    Pedal pivot clip
    Return spring
    Thanks in advance!
  • James W.
    • December 1, 1990
    • 2640
    Re: 1964 Brake/clutch pedal assembly questions
    David,
    On my '64 the items you mentioned are the following color/finishes;
    Non-power brake pushrod = natural or zinc plated
    Brake pushrod jam nut = natural or zinc plated
    Brake clevis = natural or zinc plated
    Brake clevis pin and retaining clip = natural or zinc plated
    Brake pedal pivot clip = oiled steel or black/gray phosphate
    Return spring = black/gray phosphate
    James
    Pushrod jam nut
    Clevis
    Pedal pivot clip
    Return spring
    Thanks in advance!
