1971 LT-1 replacement harmonic balancer - NCRS Discussion Boards
    • 11608
    Trying to help a friend with his car, and it appears that the harmonic balancer outer ring may have slipped. We hope to remove it in the next few days to verify, but it appears that the TDC mark is far away from actual TDC based on using a piston stop to find TDC and verify its position.
    Since the car is just a driver, he would rather order a replacement balancer and not worry about rebuilding what is on the car currently.
    In looking for a balancer, all of the 8 inch balancers marketed through Jegs, Summit, or other similar sellers note "except special high performance" for this size. I have a hard time believing that there is much difference between any stock replacement 8 inch balancers that would not allow any of them to work on an LT-1, but I thought I'd check here first and see if I'm missing something.
    Looking at balancers like these:
    Free Shipping - PowerBond Premium OEM Replacement Harmonic Balancers with qualifying orders of $109. Shop Harmonic Balancers at Summit Racing.
    https://www.jegs.com/i/JEGS/555/5165...791+4294828856
    Thanks for any comments.
  • Ed H.
    • November 19, 2015
    • 192
    Re: 1971 LT-1 replacement harmonic balancer
    I used these guys: https://www.damperdoctor.com/
    It was cheap and quick. I know you are looking for a replacement, but...
      Patrick------
      These balancers are all the size and configuration of the 8" balancers used for 1969-70 Corvettes with 300 HP (i.e. GM #3947704 and 6272222). They have a thinner balancer ring (1-5/16") than those used for L-46 and LT-1 (1-11/16"). Actually, I think they would work OK for an LT-1 but I'd be reluctant to use one myself. Using one of these balancers would not affect pulley alignment, though, as most, if not all, small block harmonic balancers have the same dimension from end of snout to pulley mounting surface.
      The last GM version of the LT-1 balancer I can find, GM #12555879, is discontinued. I do not know if there are any aftermarket equivalents. The original LT-1 balancer was GM #3947712. This was replaced by GM #6272224 and, later, GM #12555879. The 12555879 differed from the earlier in having degree marks embossed about the perimeter.
      Incidentally, the reason why the 1-5/16" X 8" balancer, including the GM #6272222 is still available, is that this balancer was used for many 350 cid truck applications. Thus, its popularity as a replacement is great.
        • 11608
        Thanks Joe. I've noticed that a lot of them list as applicable to trucks, so that makes sense.
        Paragon wants over $300 for a balancer, which is ridiculous.
        We might end up getting his rebuilt, since replacements seem difficult to find.
        • Mark G.
          • January 31, 2007
          • 177
          My personal feeling on those Summit/Jegs balancers. made in China would need to verify their accuracy, and not SFI rated. The stock ones weren't SFI rated either, but I would trust it over a made in China balancer. I'd get the original rebuilt and if originality is not a concern, I'd use a ATI balancer.
          • John S.
            • June 15, 2015
            • 505
            1973 L82 M21 4 Speed, very original and well documented driver/survivor
            NW Chapter Member, 2016 Bend Regional Top Flight
            73/74 TIM&JG 3rd Edition Revision Team Member
            • Richard G.
              • July 31, 1984
              • 1715
              You don't have to remove it to verify ring creep.
              Disconnect the battery.
              Use a stop in-place of the #1 plug. (You can buy one but I make them with an old plug)
              Rotate the motor by hand till the piston touches the plug.
              Do the same thing in the other direction.
              Split the difference between the two marks.
              The new mark is TDC on the balancer.
              Even with everything correct the TDC mark can be off because of factory tolerances.
              If you are blue printing a motor this is typically checked and verified.
              I see more incorrectly parts than slipped rings on balancers.
              Remember GM moved the TDC mark in relation to the key-way and incorrect balancers occasionally do get installed.
                • 11608
                Richard,
                See my first paragraph. We already did this - twice. It’s WAY off.
                The outer ring seems to have also moved inward, which would fit the “loose ring” scenario.
                I spoke with the owner yesterday and at this point the balancer is likely going to be rebuilt.
                Patrick
