So............ok! I've read all the posts I can find regarding harmonic balancers coming off due to various causes and the tremendous advantage of having an engine/crankshaft set up for the retaining bolt (7/16-20). Why it took Chevrolet so long to come to the conclusion that all engines should have the balancer bolted (screwed on, actually) is beyond me. But I've never found any archival posts regarding the likelihood of internal crankshaft or bearing damage caused by driving the balancer back on the crankshaft nose. My repair manual shows one being driven on with what appears to be some sort of Rube Goldberg type device (factory supplied tool, though) which does not appear to offer any protection to the shaft, thrust bearing, main or rod bearings, etc. So, what is the risk to engine internals by hammering the balancer back on? I should think that significant damage would be likely.......but am I right? I believe my balancer originally was installed at the factory leaving the balancer forward of the crankshaft nose by about one inch, + or- 1/16 inch. That is to say that the crankshaft face was one inch back of the face of the balancer. Bottom line is I'm reluctant to hammer it back on but my neighbor says I worry too much and that perfectionism is an illusion devised to bug the realists and the "get 'er done" folks of the world. Who's right? Ideally the crankshaft should be removed and drilled and tapped by a good machine shop.......but my budget can't stand that and all I had set out to do was replace the timing cover seal.........not overhaul the engine.
Thanks to all the forum experts.
Bill
Bill
