This the 3 time this has occurred: First time I lost the pedal, the fluid was a little low after a firm stop. I filled it up, but never got the pedal back. So I had the system bled and filled. Firm pedal until I drove on the highway and lost my pedal on the exit ramp. Since the bleeding did not fix the issue, I had a new m/c installed. Same thing... Firm pedal until freeway drive. Lost the brakes on freeway exit ramp. I've done a lot of research on this site and sounds like rotor runout, but I haven't changed the rotors or calipers or anything in quite awhile. The car has Repo KOs. Does this impact anything? The gentleman who has done the last two m/c installatons is dubious about the rotor runout, but now will not return my calls. Am I on the right track? Any other possible solutions? No leaking has been seen at the M/C, calipers or brake hoses.
1966 Manual brakes - Air in brake system after M/C replacement and highway driving
I had the m/c rebuilt and system bled and filled with DOT3. I had a firm brake pedal for days running town on surface roads. The first time I took on the highway(15 miles) the brakes went to the floor on the exit ramp. I'm able to stop the car using a lot of runway and the last inch or two of pedal prior to hitting the floor. If I pump the brake rapidly the pedal firms up for a second then quickly loses firmness.
This the 3 time this has occurred: First time I lost the pedal, the fluid was a little low after a firm stop. I filled it up, but never got the pedal back. So I had the system bled and filled. Firm pedal until I drove on the highway and lost my pedal on the exit ramp. Since the bleeding did not fix the issue, I had a new m/c installed. Same thing... Firm pedal until freeway drive. Lost the brakes on freeway exit ramp. I've done a lot of research on this site and sounds like rotor runout, but I haven't changed the rotors or calipers or anything in quite awhile. The car has Repo KOs. Does this impact anything? The gentleman who has done the last two m/c installatons is dubious about the rotor runout, but now will not return my calls. Am I on the right track? Any other possible solutions? No leaking has been seen at the M/C, calipers or brake hoses. -
Re: 1966 Manual brakes - Air in brake system after M/C replacement and highway drivin
William------I had the m/c rebuilt and system bled and filled with DOT3. I had a firm brake pedal for days running town on surface roads. The first time I took on the highway(15 miles) the brakes went to the floor on the exit ramp. I'm able to stop the car using a lot of runway and the last inch or two of pedal prior to hitting the floor. If I pump the brake rapidly the pedal firms up for a second then quickly loses firmness.
The first thing I would do is to measure the rotor runout, front and rear. This is not very difficult to do.In Appreciation of John Hinckley- Top
Thanks, I'll get a dial indicator and give it a whirl.- Top
Pedal goes to the floor with no evidence of leakage can be an internal leak/failure of the master cylinder. Check under the IP for fluid leakage from the end of the m/c, and discuss the situation with whoever rebuilt it.
Duke- Top
Thanks for responding. I'm trying to learn and do not mean any disrespect when I ask why would having the bleeders open impact the measurement the rotor runout? Thanks for your patience.
- Top
Duke,
I could not see any evidence of leaking outside. I will follow your direction, but am unsure what the 'IP' is that you are referring. I'm sure its very simple, but I don't know what you're referring to. Thanks.
- Top
Interesting. I will take a look. Thanks for your reply.- Top
Instrument PanelMark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
They don't. I believe Danny is merely suggesting you do both- not necessarily at the same time.Mark Edmondson
Dallas, Texas
Texas Chapter
