Engine vibration � need help diagnosing - NCRS Discussion Boards
  • Rod R.
    • August 31, 1984
    • 110
    • Gene M.
      • April 1, 1985
      • 4232
      Originally posted by Rod Runyon (7847)
      Jim, my transmission has not been rebuilt and it is the original as is the engine. It worked fine before this restoration. Do you remember if your transmission noise/vibration was speed related or constant?
      Rod
      Contradiction here, is all original or restored. Was engine and tranny removed or not. Clutch, throw out bearing, flywheel, pressure plate, pilot bushing, universal joints, drive shafts, differential, engine mounts, etc, you don’t say what was done here.
      • Perry M.
        • January 1, 1977
        • 325
        #18
        • Rod R.
          • August 31, 1984
          • 110
          #19
          did not balance it with the flywheel. This is where I think my problem my lie or with the harmonic balancer which is original and not restored. No one has addressed the pressure plate/flywheel and balancer issue and how to identify if they may be the culprit. Do you have any experience with either of these components?
          • John M.
            • January 1, 1998
            • 813
            #20
            • Rod R.
              • August 31, 1984
              • 110
              #21
              • James W.
                • December 1, 1990
                • 2640
                #22
                • Rod R.
                  • August 31, 1984
                  • 110
                  #23
                  • Darryl D.
                    • February 7, 2017
                    • 386
                    #24
                    • Rod R.
                      • August 31, 1984
                      • 110
                      #25
                      • Jim L.
                        • September 30, 1979
                        • 1805
                        #26
                        • Gene M.
                          • April 1, 1985
                          • 4232
                          #27
                          • Richard G.
                            • July 31, 1984
                            • 1715
                            #28
                            • Rod R.
                              • August 31, 1984
                              • 110
                              #29
                              • Rod R.
                                • August 31, 1984
                                • 110
                                #30
