The 73/74 TIMJG revision team after much deliberation has concluded the following and would like to confirm in support of the revised manual. Your comments are welcome.
In summary:
In regards to the A348C air filter, the following reflects the team's findings.
In summary:
- Air cleaner assemblies were shipped to the plant with an air filter installed and label attached to the base.
- The transition was limited to L48/L82 with late production (May-June) 1974
- A longer carb stud was required for use with the A348C air filter
- No LS4 left the factory with an A348C air filter
A348C Filter Element PROTECT YOUR ENGINE - REPLACE WITH AC TYPE A348C. Original filters were misted with oil which, contributed to the yellowish appearance.
