Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
1967 Corvette 427-435 factory side exhaust had no gain in Performance -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Re: 1967 Corvette 427-435 factory side exhaust had no gain in Performance
Originally posted by Danny Pantuso (63794)
Wow what a different from 2 1/2" like I said before back in 67 you wanted Performance and Horse power your running against the big boys back then on the street, I still think 427-435 is more valuable Corvette with a factory N11 exhaust system
Originally posted by Jim Durham (8797)
After hearing about the performance loss with side exhaust but wanting to keep them on my 65 big block, I did some research. I cut my OEM pipes open and it's obvious why they hurt performance so much, especially with a big block. The flow path is 1 1/2". That would be like trying to run a marathon breathing through a plastic straw. The solution, for me and several others, was to build my own using Classic Chambered VettePack mufflers. Not original I know but the performance difference is worth it to me. Joe Ciaravino, RIP, put them on his modified 65 with headers and electric cut-outs. His dyno results were impressive. Back to back runs resulted in 414 RWHP with the headers open, 408 RWHP through the side exhaust. They are a little louder than OEM pipes but sound a lot deeper. Here's a pic. of my OEM pipes cut open.
Jim, that's pretty cool. What was the RWHP with the stock side exhaust?
Steve, Joe didn't post a dyno run prior to replacing the side pipes but I can guarantee the OEM side pipes would cost way more than 6 RWHP vs. open, long tube headers. My buddy has a Superformance Cobra with a stroked 460 and picked up over 80 RWHP when he changed from the original Superformance side pipes to Classic Chambered.
I agree Jim, that's why I was curious about the difference. Losing only 6 RWHP is very impressive vs. open headers is very impressive.
Sidepipes will always add value to the vehicle. The rarer the car, the more the added value. When you start looking at the values of a 1967 435 roadster with sidepipes vs without sidepipes in the real world, there's no doubt N14 adds a bundle.
My guess is that the red/red L88 certainly would have sold for more with N14.
+1, and we all know even a '67 L88 without anything original and built around a trim tag and VIN plate brings 7 figures.........
