66 427/425 TI wiring - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 269
    I see on the published TI wiring diagram the schematic shows a 12 pink wire in diagram. It appears that that is feed from ignition but I don't see any 12 wires feeding the ignition in other schematics that I have. What gauge wire should be feeding ignition on TI system.
  • John M.
    • January 1, 1998
    • 813
    Re: 66 427/425 TI wiring
    Walter, the ignition feed for both points and TI is a 12 gage pink lead. For points it connects to the ballast resistor, for TI it connects to the TI harness through a special connector, depending on year. Check the AIM section D1 (I think)
    • Walter R.
      • January 6, 2009
      • 269
      Why do all schematics that I see show a 18 gauge wire coming from ignition switch?
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        18g goes to fuel/temp gauges and fuel sender and b PB switch. 12g also comes from IGN switch to TI or ballast for points. These 2 wires, 18g and 12g should be seen at the same terminal at the IGN switch.
        Your schematics are likely in error.
