If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
working on a 1968 C3, this is the problem; first the vacuum is only at 7in and the cowl will not lift and return, my suspicion is that the CAM was changed and now it does not produce the correct amount of vacuum, with that is there any solution? second is the wiper motor 1-5 have burnt the points out when it was installed and turned on. Any ideals ?
7" hg may not be enough to operate the doors. Do your headlight doors and HVAC operate?
Three choices I see:
- Open the door manually when needed
- Get another cam or engine with more vacuum
- Don't drive in the rain (or use a lot of RainX :-) )
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
