L76 Holley 2818 Throttle Return Spring - NCRS Discussion Boards
  • Michael D.
    Infrequent User
    • April 30, 1987
    • 10
    My 1964 L76 327/365 with the 2818 carb has only one throttle return spring. If I remove this spring, the throttle will stick wide open. On some other Holleys (Model 3310 for example) there is a spring on the throttle shaft that snap the throttle shut even on a bench. My 2818 does not have this and it seems a little unnerving relying on one return spring. I have seen double springs (smaller spring inside the larger) on some GM applications but mine does not have this. Any comments appreciated.
    Mike Delehanty
  • Leif A.
    • August 31, 1997
    • 3607
    Re: L76 Holley 2818 Throttle Return Spring
    Mike,
    The double springs are typically a "band aid" fix for an improperly adjusted or gunked up carburetor. The single spring is more than adequate to return the throttle if the carb is properly maintained.
    Leif
