Fuel gauge error
I have installed a new fuel gauge and a new sending unit. Before installation I verified that the resistance was 0-90 ohms through the sending unit. The issue is that when the tank is empty, verified by visually checking, the gauge reads empty, but when I added 5 gallons of fuel the needle on the gauge barely went above full. It also when filling the tank the needle does not display full, maybe just over 3/4 full. How do I calibrate the gauge to the sending unit? Bend the arm? Remove the gauge and then remove the needle to display the more correct fuel level?
Speedo error
327/350hp, M20 WR 4 speed, 3.36:1 posi, new blue gear at end of speedo cable (replacing the worn original), 205-75/R15 tires on original ralley wheels.
Tach is correct throughout its operating range verified by an electronic tach held in the cockpit.
My information says to me that at 2000 rpm in 4th gear my speed should be an indicated 46mph....BUT
I have a GPS AP on my phone and I checked its accuracy against my Buick and it was dead on (+/- 1mph). So when I checked in the Vette, at 2000 rpms the GPS was reading 53 mph.
How do I correct or calibrate the speedo? Just send it to Joe Ray and let him work his voodoo magic?
Snow season is approaching and Ill have several months disassembly-repair-reinstallation to get this corrected.
Don
Speedo error
Don
Of course I know nothing.
