I have a 64, original L76, rebuilt (stock) about 13 years ago. I developed a slow oil leak at the rear of the engine - it started about a year ago. Following a short drive it will lose about a tea spoon of oil, but it will continue to drip slowly for up to a week after the engine has been turned off. Oil drips from the bottom of the bell housing where it meets the inspection plate.
Thinking it was the rear main seal, I pulled the starter, oil filter and inspection plate. Have not yet removed the oil pan.
The flywheel is very clean and completely dry - it even had a slight coat of rust on the front (engine) side in some areas. Bell housing is mostly dry, some moisture at the bottom towards the front but not much. According to other threads I've read if the rear main is leaking the fly wheel should be wet. The back side of the inspection plate is pretty dry except towards the bottom. The block looks dry in the vicinity of the rear seal - at the very back of the oil pan.
I don't think I have a rear main seal problem. I checked the valve covers - dry all around, the block and top side of the bell housing are dry too. I did put a wrench on the back two bolts that hold the oil pan on, one side took about a quarter turn to make it snug, the other side took a little more than a quarter turn - they were both loose. Some wetness around both bolts.
Could those two rear pan bolts be the problem? If not, any thoughts or suggestions on where the oil is leaking from?
