63 front bumper bolts - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    Reassembling my front bumpers now and I have a mix of "M" and "TR" bolts of varying lengths....
    The AIM Section 14 drawing sheet A2 shows items 4 and 5 for the bolts; part numbers 122283 and 122267 respectively... Is this due to a difference in bolt lengths ? There are only 4 #4 bolts in the drawing (2 on each side) the rest are #5 bolts... The #4s are the two rearmost bolts attaching the center bracket to the frame....
    The bolts were mixed up when I removed them, I have four shorter bolts that were in different places between the two sides...
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 63 front bumper bolts
    Frankie,
    Earlier 63 had all TR bolts but later (don't know when) the supplier delivered WB's to GM. There were mixed bolts along the way as usually one side had WB's and the other had TR's. Then all WB's started showing up on late 63's and 64's.
    The way the stock was delivered to the line could explain the mix of bolts as new stock was on the top of the boxes the workers used. Who knows???
    JR
    • Leif A.
      • August 31, 1997
      • 3607
      Frankie,
      Don't know if this picture will help or not. The black nuts and bolts are for '67L bumpers.
      Leif
      • Frank D.
        • December 27, 2007
        • 2703
        Apparently the vendors are selling the "M" headmark bolts now, the "TR"s in repro are scarce some places it seems - the repro headmarks are bad looking anyway. My issue is that I was told that the #4 drawing bolt is 1-3/4" and the #5 is 1-1/4" by someone I trust. This works out oddly on the center brace because a longer bolt in the rearmost hole of the center brace has a lot of threads sticking out past the bolt - it looks odd...
        • Bob R.
          • June 30, 2002
          • 1595
          Just about all of the original bolts I found on my 63 had an "M" head mark and some of the rear bolts holding the bumper mounting brackets were different lengths but had the same head marking. I replaced some of them with reproduction which all had "TR" on them and were one size fits all. I saved the originals which I removed but there is too much corrosion to leave them in place.
          • David B.
            • March 1, 1980
            • 687
            GM Standards specifies BOLT #122267 as 7/16 - 14 X 1 1/4 zinc
            BOLT # 122283 is listed but not specified
            BOLT # 122293 is listed as 7/16 - 14 X 1 3/4 zinc
              • 6940
              Frank I am sure that Long Island Corvette sell there kits with a mix of TR and M.
              • Frank D.
                • December 27, 2007
                • 2703
                Thanks I got some repro M's and had some repro TRs already - managed to save about 6 original TRs...
                Got the bumpers and correct "thick" brackets together today and its all setup, straight, correct and good-to-go.
                Thanks All...
                • John D.
                  • December 1, 1979
                  • 5507
                  My 63, the LWC has WB front bumper bolts. Another '63 I had in the 19400 range had TR & M front bumper bolts Joe Ray. John D.
                  • Joe R.
                    • July 31, 1976
                    • 4547
                    Having a 63 with M bumper bolts just means that (having it) doesn't necessarily mean it's original.
                    Sounds like the old (my 63 is original) story!
                    JR
                    • Rick A.
                      • July 31, 2002
                      • 2147
                      when we tore Lady, my 1963 Z06 apart she had ALL WB's
                      Rick Aleshire
                      2016 Ebony C7R Z06 "ROSA"
                      • John D.
                        • December 1, 1979
                        • 5507
                        Jorjorian has a '63 with serial number close to mine Joe Ray. Front Bumpers = WBs.
                        • Joe R.
                          • July 31, 1976
                          • 4547
                          John,
                          Check your response above. You said M's! WB's yes but I doubt any original 63's had any M bolts! Unless of course they were ordered from Long Island. TR's were the most common and WB's later in the year!
                          JR
                          • Rich Y.
                            Infrequent User
                            • April 1, 2012
                            • 24
                            I have an very original and unrestored February '63 convertible.
                            The bolts are all WB and show every sign of never being disturbed.
