For years now I've been befuddled about the ignition timing on my 63 fuelie. To get it to idle and run reasonably it takes way more advance than specified. When I say way more I mean like 30 degrees at idle with the vacuum advance line blocked off! I've just discovered the same issue with the newly rebuilt 265 V8 in my 55. I don't get it. What is going on?
I don't live at altitude, maybe 2500 feet.
Since two cars exhibit the same strange behavior I thought maybe my timing light was screwed up. So I bought another one and got the same results. Double checked to make sure I hooked it to the correct spark plug wire too.
On my 63 I thought maybe the harmonic balancer had slipped. Also thought maybe I have the wrong timing cover and the timing tab is in the wrong place. Doesn't seem like either and very odd that I now have another engine doing the same.
Any ideas?
Any ideas?
