1976 Owners packet - NCRS Discussion Boards
1976 Owners packet
  • Rick B.
    Infrequent User
    • December 11, 2016
    • 17
    1976 Owners packet
    So I always lose a point for an Emissions Control Information document. My car was not emissions equipped car like a California car. But either way, what does this document look like and does anyone know where I can pick one up? Also in the judging manual table for documents, some items have a X in the column and some columns are blank. When it has an X does the mean the packet should have that document?
  • Dick W.
    • 10483
    Re: 1976 Owners packet
    Look here http://osborn-reproduction.com/catal..._Position=PAR:
    Dick Whittington
    • Rick B.
      Infrequent User
      • December 11, 2016
      • 17
      Thanks but it was not there.
      • Jimmy P.
        • June 24, 2014
        • 1695
        Rick,
        Are you sure ( or I should ask if the judges are sure the emissions pamphlet came in the 76)? I've only seen it with the owner's packet up thru 1974. I don't think it was present after that. I'm not positive but here's what came with the 76.
        : Warranty Information on 1976 Chevrolet New Cars
        : 1976 Chevrolet passenger car maintenance schedule
        : Passenger tire limited warranty
        : Freedom Battery warranty
        : 1976 Consumer Info Booklet - Corvette
        : Aluminum Wheel maintenance schedule sheet (RPO Y J8)
        : Owners Manual
        : Clear Plastic Envelope
        Heres what the 73&74 Emissions Pamphlets look like?
        If these were present for 75 & later cars hopefully someone will post up a photo.
        I don't have a 76 TIM&JG Rick, but I would think the x means it should be there. Might be time for a 75-77 Revision!
        Jimmy
        1973 Convertible
        L48,M20,N40
        Mille Miglia Red/Oxblood
        • Rick B.
          Infrequent User
          • December 11, 2016
          • 17
          Here is the page.75-76 TIM&JG Packet.pdf
          • Jimmy P.
            • June 24, 2014
            • 1695
            That's interesting. I can see why you asked what the X means. It appears under 76 across from warranty info. All the cars had that. But then there are X's all the way across from the Radio Instructions, which stopped with 73. Confusing Maybe missing part numbers
            Maybe someone will chime in with some help. BTW, if you have your 76 AIM check the Miscellaneous Shipping List Page toward the front to see if the Emission Control Booklet is listed. It will have the part number listed too.
            Jimmy
            1973 Convertible
            L48,M20,N40
