I could use some help in selecting the best vacuum canister for my engine. I am in the process of trying to set and map the ignition advance. Here is what I have:
1957 Corvette Driver
327 CI + .030
375 (1963) Rochester Fuel Unit.
Melling 22200 Hydraulic Cam
Compression Ratio 9.5:1 (calculated)
Restored fuel unit, engine rebuilt - first run-in
Advance converted to full time manifold vacuum
The engine is making only 11 -12" Hg vacuum at idle. I have the centrifugal weights wired closed until I get the vacuum working right. I have lighter springs for the centrifugal when I get to that point.
When I bought the injection unit in 1970 it had a B1 vacuum canister. I don't have a specification for what canister it was suppose to have, but given that the B1 is a poor choice and being factory configured with port advance that might well have been the factory supplied can. The engine now has a B22 can as supplied by the FI restorer. That wont work as a B22 needs 16" + the 2 inch rule.
In looking over the listing of different vacuum cans GM made I don't see a real good match. The listing I have does not include 1963, for whatever the reason, but that certainly is not what I would use anyhow. Mood point.
The B20/B26 (may be no longer available) would be marginal; 11 - 13" for full in. The only other choice I see is a B28 which may be too aggressive - 5.75 - 8" full in. This is the canister they used with the 30-30 cam. The advance will come in very quickly with this can.
The Melling cam I have is fairly aggressive - 222* duration - same as the 097 cam only hydraulic.
So what do you guys think? All recommendations are welcome.
One other question - how do you set dwell on these FI units? The distributor cap window points straight to the front of the engine, and has about 3/4" clearance to the back of the plenum. It is impossible to get an Allen wrench on the adjuster screw. If I retard the timing enough to access the screw the can hits the coil bracket and is so retarded it wont run. So what I did is retard it all I could with the engine off where I could just barely get a wrench on it and turn it a little bit. Then advance the timing back, start the engine and measure dwell. Several attempts later I hit 30*. There must be an easier way.
Appreciate all help and advice.
-Dan-
327 CI + .030
-Dan-
