Oil Pan Gasket - NCRS Discussion Boards
Oil Pan Gasket
  • Walter R.
    • January 6, 2009
    • 269
    Oil Pan Gasket
    Need an oil pan gasket for 66/427. I went to two parts suppliers and the gaskets they had,or could get did, not have a hole in center of front gasket for center bolt. Is there a supplier of this gasket with center hole or do we drill hole in gasket?
    Re: Oil Pan Gasket
    Walter------
    The only way you're going to get a gasket set with the hole in the front gasket is to find a VERY old NOS set of GM #3867764.
