Hi Guys,
When I bought my '66 427 AC convertible back in 1988 her AC compressor and brackets were missing. Through those early years of ownership I'd always thought that the compressor front and rear cast brackets were the same for the '66 thru '74 model years. I knew the '66 AIM had unique part numbers vs. the '67 and later cars, but I'd never seen a set of these brackets anywhere. Well, even if I had seen a real set it would've been very difficult to identify them from the '67 -'74 parts with them installed on the cars.
About 10 years ago I met a great guy through the NCRS Technical Discussion Board. He's very knowledgeable of the midyear AC system and components. He had a set of these 2 rare cast '66 only brackets. He posted some photos of the front and rear '66 427 AC brackets on the Forum. Finally! I knew what a real set looked like. Later that year he was kind enough to sell his brackets to me. These 2 brackets are shown here and will go on my '66 when I install my AC compressor.
Through the years since then I've been lucky enough to find 2 more sets of these rare '66 brackets. They are:
Front- #3887166
Rear- #3887165
The reason I'm posting this thread is to help those out there of what to look for when comparing these brackets from each other. Trying to help since this can be an expensive decision. During this thread I'll post numerous shots of the '66 only brackets. I'll then compare them alongside or to the '67 thru '74 AC compressor brackets. They are:
Front- #3894362
Rear- #3894364
Since my brackets are loose now this is the perfect time to show you all a good comparison of these parts. First, let's compare the '66 vs. the '67 thru '74 front brackets. The last photo is of the underside of these 2 parts. The '66 bracket is on the left with traces of orange paint. Enjoy. Mike
Front- #3887166
Rear- #3887165
Front- #3894362
Rear- #3894364
I have a bad habit of saying "side" bracket when I should say "rear" bracket as the parts catalogs state. However, these brackets are installed on the rear/side of the engine on the right exhaust manifold. In future posts if I say either we'll call them synonymous.
