Door Ajar, Courtesy, Hood Ajar lamps on a late'69 - NCRS Discussion Boards
  • Richard K.
    • April 1, 1988
    • 207
    After some time I determined what switches go where. I found out that the switches on my car are in all the wrong places.
    I've purchased all new, correct configuration switches (have sx), and terminals.
    My dilemma is that, in all my years, I've never learned or seen the correct way of installing them on a car. I'm ok with crimping on new terminals and plugging them into the switches. Do you plug in the terminals after the switches are placed on the body (appears to be a hard, blind reach)? My main concern is with installing the switches on the body. My fear is collapsing the switch, or damaging the door when the door is fully closed after the switches are installed. Do you install them as far as they will screw into the body, then start backing them out until they're in the correct position to light the appropriate lamp? Or, what is the best way to install them.?
    Thanks in advance.
    Rich Kossum
    • 6940
    Re: Door Ajar, Courtesy, Hood Ajar lamps on a late'69
    Rich the switches are self setting the first time you close the door they will adjust to each door. The electric leads on switches should be plugged in before install. I would also do a test fit of switches there is a post in similar threads below that says the reproduction switch may be to big. It has been awhile since I removed my 72 switches and wires from switch but as I recall a small metal pic is what I used to release the wires from switch, If you have some replacement connectors just take a close look at how they release. and if the original wires connectors are still good I would re-use them.
