Does anyone know the required valve lash on 64 - 327- 365hp?
1964 valve lash
Re: 1964 valve lash
Mike-
Ed is a smart aleck.
It's actually .026 I and E.
Give this a read, and see if it helps you. John Hinckley and Duke Williams are experts in camshaft dynamics.
- Top
Re: 1964 valve lash
Don is correct on both counts, I am a "smart aleck" and....., according to the Hinckley / Williams paper, the lash is best set at .026 I & E (cold). Shop manual specifies 30 - 30 hot. Personally, I would think that making the adjustment cold would be a lot easier. Recommendation - go with the .026.Ed- Top
Re: 1964 valve lash
Actually, the latest revision of that paper (Sept/08) recommends .023". It's on the Web, but so are earlier versions that recommended .026". The reason for the tighter lash recommendation is explained in the paper. Also, it's critically important to use the recommended indexing scheme to assure that the lifter is on the base circle for each valve when clearance is adjusted.
Duke- Top
Re: 1964 valve lash
Thanks for setting us both straight Duke, I should have remembered, I do have your later paper on that subject where you recommend .023, and I am sure Don is aware of it as well. We (Don & I) both need a lot of adult supervision.Ed- Top
Re: 1964 valve lash
Sure, you can do it that way if you like getting your hands burned with hot oil and make a total mess in your engine compartment.
Doing it cold using the recommended indexing procedure to ensure the lifter is on the base circle, you can proceed at your own pace, make the final adjustment more accurate, not get you hands burned with hot oil, and not make a mess in the engine compartment... your choice.
BTW, since the steel pushrods expand at nearly the same rate as cast iron block/heads, and "hot" (idling) the exhaust valve is not sufficiently hot to cause significant valve stem expansion, I have never measured any meaningful difference between "hot" (idling) and cold. If an engine has aluminum heads and/or block, it's a different story.
Duke- Top
Re: 1964 valve lash
I recently set my LT1 to the latest figures I found John had given, COLD LASH .021 intake .026 exhaust using the base circle method.
Are these settings still currently applicable?James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
Re: 1964 valve lash
I think the version that Duke is referring to as being the latest on solid lifter lash adjustment is attached as a PDF file.Ed- Top
Re: 1964 valve lash
"26/26 cam" doesn't have the same ring to it.Don is correct on both counts, I am a "smart aleck" and....., according to the Hinckley / Williams paper, the lash is best set at .026 I & E (cold). Shop manual specifies 30 - 30 hot. Personally, I would think that making the adjustment cold would be a lot easier. Recommendation - go with the .026.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
