1957 throtte arm bell crank - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    does any one make the seal that would seal the throttle bell cark to the firewall. Were the bel crank coms through the firewall.Was the bell crank /throttle arm . The part that is on the inside and that the pedal pushes against and goes trough the firewall . Semi flat baock or cadmium
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1957 throtte arm bell crank
    dan: both of the 57 FI's we own and I restored , had no fabricated seal. on re-assembly, I ran a bead of 3_m strip caulk on the bellcrank and bolted the unit in place . the arm of the throttle that contacts the throttle pedal gets semi-gloss black. mike
