1966 Dome light issue - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
  • Gary J.
    • April 1, 1980
    • 1229
    Re: 1966 Dome light issue
    The dome light is held in place by 2 self tapping screws. Remove the cover and you will see the screws. There are two U shape clips that attaches to the fiberglass halo that the screws pass through. That should get you started.
    • Harry L.
      • December 22, 2008
      • 370
      Thanks, I will remove the light fixture tomorrow and inspect the connection, hoping to find what could be vibrating.
      • John F.
        • March 23, 2008
        • 2395
        Did you take any pictures?
        • Harry L.
          • December 22, 2008
          • 370
          Maybe the light bulb holder is rattling against the case? Could that be?
          • Gary J.
            • April 1, 1980
            • 1229
            Remove the socket from the housing and go for a ride. See if you have a cause and effect.
            • Harry L.
              • December 22, 2008
              • 370
              Thanks, does that socket just snap on to the light assembly?
              • Gary J.
                • April 1, 1980
                • 1229
                Yes the light socket can be removed....
                • Harry L.
                  • December 22, 2008
                  • 370
                  Okay Gary, I removed the light fixture, went for a ride, still have the vibration sound, if I pushed my hand against that rubber blob, the sound diminishes somewhat. If I slide my fingers up in the hole towards the front I can feel some of that rubber touching the headliner. What could be the purpose of that rubber? Is there a stock ceiling connection that the rubber is hiding?
                  • Gary J.
                    • April 1, 1980
                    • 1229
                    Harry, probably not what you want to hear, now you need to remove the rear window trim, then remove the halo. Probably what has happen is the bonding adhesive has broke loose where the top bonds to the top of the bird cage. You may could caulk that area or put some expoxy glue in the area. Some others may some ideas. Go for a ride again after removing the items so you can isolate the area, then have a plan of attack.
