1970 Radiator Core Support Bolts - NCRS Discussion Boards
  • Allen N.
    • January 1, 2003
    • 288
    The 1970 radiator brackets at the top are attached by four black phosphate hex headed bolts. Two of them are GM 180080 and are 5/16-18 X 1-1/4". How are the GM 179832 and 9419032 bolts different from the 180080?
  • Michael C.
    • May 3, 2015
    • 55
    Re: 1970 Radiator Core Support Bolts
    on my 72 ls5 i have 179823 which is 1 1/4" long but with a small shoulder. 180080 is 1 1/4" but is threaded all the way. 9419032 is a grade 8 bolt that is 1 1/2" long. ill post a picture
    • David B.
      • March 1, 1980
      • 687
      180080 5/16 -18 x 1 1/8 long zinc
      179832 3/8 - 16 x 7/16 long plain
      9419032 5/16 - 18 x 1 1/4 long phosphate coated GM 4435 code A
      179823 5/16 - 18 x 1 5/8 long plain
      All are similar appearing Hexagon bolts
      • Michael C.
        • May 3, 2015
        • 55
        Top bolt is the #178923 which is grade 8 and the bottom is the #9419032. I had them reversed in my prior reply. Finish may be incorrect
        • David B.
          • March 1, 1980
          • 687
          178923 is an Inverted Flared Tube Fitting for 7/16 tube, pipe thread size 1/4 Brass chrome-bright
          I think you mean 179823 GM 280-M steel 2A thread
          • Michael C.
            • May 3, 2015
            • 55
