'72 LS-5 Belt question - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I looked through my AIM tonight for the part number for the water pump to a/c and A.I.R. pump belt. That combination doesn't seem to be in the AIM. Not looking for a GM belt, just a replacement. Anyone know the size? Part number for the original would help if the size is unknown so I can cross it over. Thanks!
    Re: '72 LS-5 Belt question
    Tom------
    The original part number was GM #3921905. This was a belt of 49-1/2" length and an oddball 15/32" width. GM replaced it with a belt of 49-1/2" length and 7/16" width. It's discontinued, too, but you should be able to find such a belt pretty easily in he aftermarket.
    • Tom L.
      • October 17, 2006
      • 1439
      Thanks Joe, one clarification. Is the 49 1/2" dimension the effective length or circumference? Thanks!
      • Dick W.
        • 10483
        Napa 15495
        Dick Whittington
          Tom------
          I do not know. GM never specified in parts information what convention was used. However, I think that the difference between effective length and outside circumference is close enough that for this application it will make no significant difference.
          • Tom L.
            • October 17, 2006
            • 1439
            Thanks for the belt size. Going to finally pick one up today and put it on later.
            Since owning my car I haven't had an A.I.R. pump on it. Since there is adjustment on the pump and the a/c compressor, is there a specific procedure to tighten the belt??
