Late 1957 Fuse panel hits dash brace - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    I have a August car with the dash braces . There are 3 holes in the firewall were the fuse panel goes . If you install it on the 2 inboard screws italmost hits the the dash brace . The distance on the third outboard hole is in the right place for the fuse panel also . But when put there the wires are a little short . Could the outboard hole be where they moved the fuse panel out to clear the brace. I can stretch the wires and make it work there.
  • David S.
    • December 1, 1982
    • 310
    Re: Late 1957 Fuse panel hits dash brace
    Dan a few pictures of the location of the panel in a June car
    • David S.
      • December 1, 1982
      • 310
      Dan a few more from a July car # 55xx
      • Dan P.
        • December 1, 1990
        • 683
        That explains the third hole .Thanks for all you help
