Lock Washers on '67 Water Pump Bolts - NCRS Discussion Boards
  • Brad K.
    • August 31, 1990
    • 414
    I am assuming that because there is no mention of lock washers on the bolts securing the water pumps on '67 small blocks, in version 6.0 of the judging manual, that there are none? Can anyone confirm this?......Brad
    • 43193
    Re: Lock Washers on '67 Water Pump Bolts
    Brad------
    No lockwashers on waterpump bolts or studs for 1967 or any other year, big block or small block. If there is a double ended stud, there may be a lockwasher used on the OUTER portion of the stud in the fastening system of whatever is attached to the stud (e.g. alternator brace, etc.). But, between the bolt or stud and the waterpump casting, no lockwasher.
    • Brad K.
      • August 31, 1990
      • 414
      Thanks, Joe....Just curious......What was the original engineering rationale for having bolts only with no lock washers? Brad
      • Peter H.
        • April 1, 1980
        • 223
        My guess would be a coolant leak out the slot of the lock washer...peter...
          • 43193
          Brad------
          I don't know what the rationale was. It could be that the engineer responsible felt that these bolts were not susceptible to loosening in service. Or, it could be that the engineer never bought into the notion that split lockwashers had any real effectiveness.
          As far as I know, lockwashers were never used under the head of the waterpump retaining bolts on any small block or big block.
          • Edward B.
            • January 1, 1988
            • 537
            It could be that the engineer never bought into the notion that split lockwashers had any real effectiveness.
            +1 Lots of information available showing their ineffectiveness.
