Re: 1967 Coupe with A/C Heater Core replacement
Just an update on the '67 Coupe A/C heater core replacement. My local radiator shop was able to locate original heater core stock from a company I believe is in Michigan. It was cut to length and they used my original tanks. See the attached photo.
The heater box was disassembled, cleaned and new foam door seals installed.
Mike, I was unable to get information on the bolt head inside the evaporator. Sorry.
There was a delay in actually installing the completed box due to the cold weather here in New Jersey, but today there was success. In about 3 hours, with the help of my good buddy, the heater box was installed and heater hoses hooked up. In our next session, the inside cables, vacuum lines, wiring, clock, radio, duct work and glove box will be worked on.
And now, on to the questions of the day. The A/C wiring harness had 2 strange looking light sockets that were hanging down behind the clock. Apparently Bubba was back there in the past and unhooked these lights. It appears they would be used to illuminate the upper A/C controls on the dashboard and that they should be installed inside the center, upper A/C dash outlet. There is slots in this duct where the control cables pass through and the flexible hoses attach to. Would these light sockets enter the duct in the same spot? How do these attach and in what direction and how are they oriented? I have attached a photo of one of these light sockets. The assembly manual does not show enough detail. The clock light sockets are of a different design.
I appreciate all the assistance so far on this difficult project but I am over the worst and hope there are no other major issues.
