1957 firewall gromet sealer compound - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    The AM calls for part number 3686628 which is the gray body caulking .The fire wall grommets on the car when I took it apart appeasers to have a black sealant on them ??. Like black roofing tar. Which is correct.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1957 firewall gromet sealer compound
    my grommets off our three 57's , as well as the 55, 56, 61,61 and 62 vets, were sealed with a black caulk. you would think that if they were originally gray, there would be evidence of grey color buried within a cross-section of the caulk. I've used 3-M strip caulk during the above restorations. mike
    • Dan P.
      • December 1, 1990
      • 683
      Thanks for all you help
      • David S.
        • December 1, 1982
        • 310
        Dan I would;d go with the black.
        See below pictures from two original cars
        Dave
        • Dan P.
          • December 1, 1990
          • 683
          Thanks for all your help
          • Wayne G.
            • April 30, 1984
            • 143
            Dan,
            There is a good article in an old Restorer magazine with regards to this. I will send a copy to you.
            Wayne
            • Dan P.
              • December 1, 1990
              • 683
              Thanks looking forward to it.
              • Steven B.
                • June 30, 1982
                • 3976
                Finally got around to pulling some of my original caulk apart on mid Dec '56 assembly and it is black throughout.
                • Wayne G.
                  • April 30, 1984
                  • 143
                  Dan,
                  The article in the Restorer Magazine with regards to the grommet sealing is in Volume 37, Number 4 Spring 2011.
                  In case you don't have that Volume I've scanned it and will send to you on a PM.
                  Wayne
