Re: Is this flywheel OK to use.
Joe and Don, I checked a 366861N and a 3791021. Both measure .970 disc surface to crank surface. 861N weighs about 25 LB and the 021 about 30 LB. 861N rings like a bell and the 021 has a weak ring sound. It also has a very different shape on it's engine side. Not sure if 021 is nodular or gray iron. When I get a chance I'd like to check this 021 flywheel to see if the graphite is nodular or flake form(in gray iron). A polish and magnify would tell this. 021 came in 6500 redline cars! Don if your car has a 3:08 or 3:36 rear end, the 30 LB might be best. If it's 3:55- 4:11 the 25 LB 861N flywheel would give your L79 a little more crisp acceleration once the car is rolling. The heavier flywheel helps getting the car rolling from stop better. The 861N I have came out of a 65 with 3:36 rear end and that owner had no issues. After seeing how many of that flywheel are available from a boat application which puts no wear on the friction surface, it seems an appealing choice.
