Need help with 1967 wiper arm/holder/blade assenmbly - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    I have a 1967 March 9th production 427. The wiper arms say TRICO; however, at the far end of the arm there is an ANCO holder..see pics. Is the ANCO holder correct for this car (I'm thinking not)? If not how do you get this ANCO holder off the end of the arm? I also sent a pic of the blade assembly that I bought at a swap meet that says TRICO; made in USA at both ends (15"). I'm thinking this is what should go on the end of the TRICO arm.
  • Wayne L.
    • September 30, 1981
    • 233
    Re: Need help with 1967 wiper arm/holder/blade assenmbly
    The blade holder stamped TRICO made in USA is not correct for a 1967. Correct 1967 blade holder would be stamped just TRICO. 1967 Corvettes were supplied with either ANCO or TRICO blade holders.
    • Dave K.
      • January 24, 2013
      • 278
      Wayne. I want to make sure were speaking the same language. In the pics I provided there is a wiper ARM that says TRICO and at the end there is an attachment that I am calling the holder and it says ANCO on it. . This holder will not connect to the other pic that shows what I call the wiper blade (or part of the holder) assembly which says TRICO made in USA at both ends. The 67'judging guide pg 72 says starting in Mid-january of 67' GM phased in the TRICO-made in USA holders on one end and gradually phased in TRCO-made in USA on both ends throughout the rest of the 67 production year.
      • Russ S.
        • April 30, 1982
        • 2161
        In your first picture, the anco piece needs to be removed from the Trico arm. Then your trico blade will fit on the trico arm.
