ignition switch - NCRS Discussion Boards
ignition switch
  • Daniel Y.
    • September 30, 2002
    • 185
    Re: ignition switch
    Gary,
    I can understand your theory. I wish they were the same. you would think they would be the same. but they aren't. if you can get Pete Lindahl on the phone he can clear things up. he's gone through a bunch of them and given classes on differences. he's a key and lock specialist.
    Good Luck,
    Dan
    Dan Young
    65, 67 Duntov x2
    66 bowtie x 2
    71 LT1 TF
    90 ZR1 McCelland
    03 Anniverary
    06 Z06
    • Joe R.
      • July 31, 1976
      • 4547
      Re: ignition switch
      Here's a picture of the two switches. This should give you the difference in the two switches right away. At least the physical difference.
      JR
      • Gary B.
        • February 1, 1997
        • 6979
        #18
        Re: ignition switch
        JR,
        The switch on the right is the incorrect version of the 686 switch. That switch will not function correctly during judging. The original 686 switch had two brass pins, the same as the 673 switch in your photo on the left.
        Gary
        • Joe R.
          • July 31, 1976
          • 4547
          #19
          Re: ignition switch
          Gary,
          Where did you get your information? I have several 686 switches removed from what I thought was original instrument clusters and none of the 686 switches have two pins including the reproductions.
          JR
          • Bob W.
            • December 1, 1977
            • 799
            #20
            Re: ignition switch
            Is there anyone who restores this switches?
            Bob
            • Gary B.
              • February 1, 1997
              • 6979
              #21
              Re: ignition switch
              JR,
              Without the 2nd pin the push-in to turn to ACC feature will not work. Yes, there are lot of 1-pin 686s and repros out there, and the production 2-pin version is very hard to find, so as switches wear out they become replaced with 1-pin versions. Check the DB archives for more info/confirmation.
              Gary
              • Peter L.
                • May 31, 1983
                • 1930
                #22
                Re: ignition switch
                Joe - The Delco-Remy p/n 1116686 (embossed "686") ignition switch that was in & still is in our 1967 SN #1476 that we purchased in 1983 had the 2 brass push pins in the lock cylinder bore. Pete
                • Joe R.
                  • July 31, 1976
                  • 4547
                  #23
                  Re: ignition switch
                  Pete, Does the Tumbler cylinder face plate have one or two holes or is the hole offset?
                  Thanks, Joe
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    #24
                    Re: ignition switch
                    JR,
                    Original face plates have one hole. That 2nd brass pin in the 66 and 67 lock switches is never depressed via a paper clip in the hole as is done when removing the lock core. The paper clip only depresses the 1st brass pin.
                    Gary
                    • Joe R.
                      • July 31, 1976
                      • 4547
                      #25
                      Re: ignition switch
                      Originally posted by Gary Beaupre (28818)
                      JR,
                      Gary
                      Sure, then why was the second pin added along with the second hole in the face plate? That would not be used for a replacement for earlier switches because earlier switches don't have the blade slot. Another GM vehicle maybe?
                      Show us some pictures of your research.
                      Thanks, JR
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        #26
                        Re: ignition switch
                        JR,
                        Yes, the existence of a 2nd hole in the face plate always indicates that the same lock cylinder was used for another GM vehicle.
                        The 2nd pin on original 673 and 686 switches has nothing to do with the 2nd hole that sometimes exists on face plates of lock cores intended for different applications.
                        Gary
                          #27
                          Re: ignition switch
                          JR,
                          Gary
                          Gary------
                          The ignition lock cylinder used for 1967 Corvettes was the same one used for virtually all other 1967 vehicles across the entire GM line.
                          The SERVICE lock cylinder, GM #7033216 (uncoded), had only a single hole in the face plate. It's possible that this was a SERVICE piece and not the same as used in PRODUCTION.
                          • Daniel Y.
                            • 185
                            #28
                            Re: ignition switch
                            hmmmm - I bought a 67 Chevelle switch and it was the same except not light bulb holder. other wise it worked identical
                            Dan Young
                            65, 67 Duntov x2
                            66 bowtie x 2
                            71 LT1 TF
                            90 ZR1 McCelland
                            03 Anniverary
                            06 Z06
                            • Gary B.
                              • February 1, 1997
                              • 6979
                              #29
                              Re: ignition switch
                              Dan,
                              What's the embossed # on the Chevelle switch? I like your idea of bonding a cannibalized light fixture if that's a way to create a correct functioning pseudo-686 switch.
                              Gary
                                #30
                                Re: ignition switch
                                Dan,
                                Gary
                                Gary-----
                                The 1967 Chevelle switch was GM #1116685. This was a "dual brass pin" switch.
